The second iteration of Samsung Galaxy Tab tablet computers with a 7.0-inch screen. Model numbers: GT-P3105, GT-P3100, and GT-P3105.
125 Questions View all
What will I do when my battery is not charging
When im charging my tab it charges but when I turn on my tab it continues to turn off and even I charge them for many hours like 9 hrs or 10 it not charges and it still 26% and also when i charge my tab for many hours it still lowbat and never get full charge or 100% please help me thank you :)
Score 2
1 Comment
I hate when this happens, like right now its completely dead and i will have it on the charger all day and night. And it will turn with a screen with a battery and then another screen with the same battery to show how much it is charging.And then it'll turn off.
by
Add a comment
1 Answer
Most Helpful Answer
Go to setting -> about -> status -> check the power source identification (when you plug the charger is must show as "AC" anyhow it's showing USB when you plug the charger you can do below steps to troubleshoot the fault)
1) Change the charger and check.
2) Repair/ Replace the Micro USB interface and check
3) if the same fault remain you need to check power management IC
if power source properly identified by tab you can check the Battery capacity using battery analyzer. and check the power consumption using variable power supply
Score 1
1 Comment:
My Tab will say a full charge but when I turn it on it will go down in a couple of minutes. It will not stay charged.
by
Add a comment
Add your answer
yukiro will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 16
All Time: 898
