The second generation HTC One—dubbed the HTC One (M8)—features a dual flash and the new Sense 6 UI, and was released March 25, 2014.
202 Questions View all
Which replacement to use for a weak USB port?
My USB port seems to be weak. It's only charging if I hold the cable in a certain position.
Cleaning the USB port didn't help and I tried several different cables.
Want to replace the USB port and I'm wondering what's the difference of the "Charging assembly" and the "Headphone jack and USB assembly"?
Score 1
Add a comment
1 Answer
Most Helpful Answer
In fact, they are the same thing. But USB port is different from the assembly. HTC One M8 charging assembly also called USB board is coming with USB port and headphone jack just like that. It's much easier to replace the whole assembly if you need to repair. While replacing USB port only is a little difficult and complicated because it need to be soldered.
Score 1
Add a comment
Add your answer
Philipp Hofstetter will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 252
