Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66 GHz Core i7 Processors
590 Questions View all
Logic Board of i5 & i7 - difference for replace?
Hallo,
My macbook pro i7 fell to the ground.
Lower case, Upper case and cover of the display is Demage But everything worked perfectly.
I would buy another macbook pro 15" and replace all the internal components of the fallen.
If I buy an i5 model or a 2009 model, can I replace the logic board and display high resolution?
If this is not possible, you can tell the parts relating to the whole of the MacBook casing (including top) ?
Thanks so much.
Score 2
Add a comment
1 Answer
Most Helpful Answer
The i5 components are compatible and interchangeable with the i7 machine. However, due to a complete internal design change, the 2009 model is not compatible or interchangeable with the i5 or i7 models.
Good luck!
Score 1
Add a comment
Add your answer
Roby will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 13
All Time: 3,361
