Repair information and guides for the fifth generation of iPhone. Model: A1387
2201 Questions View all
What happend if I remove wifi ic and turn on phone?
my wifi ic is dead(grayed out) i over heat wifi ic and my phone is not turn on (not get start). when i start my phone wifi ic start heating and when charger is connected then wifi ic start heating. So if i remove wifi ic is my phone get turn on. pls tell me what will happen.... pls help.
Score 1
Add a comment
If you remove the wifi IC, the phone will not have wifi. So you'd be no better off now than when you started. There is a high possibility to cause further board damage if you are not careful.
Add a comment
When you heat your iPhone it will show that the iPhone is hot so keep it in the freezer for 10 minutes and it will ok
Add a comment
Add your answer
onkar will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 12
All Time: 434
