Model A1040 / 10, 15, 20, 30, or 40 GB hard drive / four touch-sensitive LED backlit buttons above touch wheel
97 Questions View all
Battery replaced slide bar to unlock does not work
Ipod Touch 3rd gen - we replaced the battery. It charges quickly and completely. I restored it through my iTunes account via cable. Only problem is that I cannot slide the bar to unlock.
Add a comment
1 Answer
The hold switch probably got misaligned when you put the iPod back together. You need to open it again, and move the hold switch on the back panel into the same position as the little black switch on the logic board, and put it back together like that. Then, when you move the hold switch, it should work.
Also, before putting it back together, you can turn on the iPod and make sure that the little black switch on the logic board works.
Add a comment
Add your answer
bnailchi will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 67
