2
Score
Avatar
Lance7
25
Asked
Water Damage,Touchscreen will not work?
History
My iPod Touch 3G 32 Meg was on the kitchen counter and got wet when the dishes were washed. Everything works ok except the touchscreen! Can anyone recomend what I need to do to fix it? Or recommend a reliable,inexpensive repair service center.
thanks
Edited by: nick ( )
Post Answer
4
Score
Avatar
markus weiher
22.7k
Answered
PermalinkHistory
I would not go that far an thay that everything is ruined.
there are a few things to do when a device like that has a fluid damage.
first of all, get the opening tools, some isopropyl alcohol (>90%) or an electronics cleaner and a soft paintbrush.
use the logic board guide of the 2nd generation iPod touch to disassemble your's.
check everything for fulid residue, it looks white/greenish and is conductive - so it shortens the parts and thats why most damaged devices won't work properly.
remove this resifure with the alcohol/paintbrush - but be careful - the parts inside the iPod are fragile. don't forget to check the connectors too. after you're done - let it dry - let it good dry, don't use a hair dryer and then reassemble it and start the device.
good luck
0
Score
Avatar
Piero
Answered
PermalinkHistory
Do what Markus said then if no luck replace the digitizer. Which I have done but still no luck.
Edited by: Piero ( )
Add Your Answer
