Released October 24, 2011 / 2.2, 2.4, or 2.5 GHz Quad-core Intel Core i7 Processor
405 Questions View all
Adhesive for the glass on the screen
Hi, I had to replace the glass cover as the old one had cracked.
The only problem is that the new perspex/glass cover had only double sided sticky tape on it to hold it onto the metal behind it and is coming off every time I open/close my mac even after removing the old glue from the metal section
I was wondering if there is any sort of adhesive strips I could get to attach it properly or even double sided sticky foam but what thickness would you recommend..
I've searched online and I can't find any strips to buy locally (I live in the UK) so I would be happy using the foam but I'm unsure as to the thickness.. :S
Many thanks!!
Score 1
Add a comment
Most Helpful Answer
Before buying another kind of tape try heating up the glass and with a cloth (so you don't burn your fingers) go around pushing it agains the frame. Don't heat it too much so you don't melt the rubber gasket
Score 1
Add a comment
I use Red tape for repairs like this. Found on eBay just search for "red repair tape" 8 or 10mm should work for you
Add a comment
Add your answer
kcnbob will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 956
