Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
Fixed water damaged iPhone iTunes error 9?
Hello everyone.
I purchased a week ago a water damaged iPhone 6 (it has a little crack on the glass too), the device didn't turn on at all. After cleaning the Logic board with contact liquid and changing the battery with a New one, the device fortunatly did show some sign of life!
Now the problem is, when I turn it on the apple logo appears for 2 seconds long and then I get a black screen with backlight on. I tried connecting it with the latest iTunes version (it says the iPhone is in recovery mode) but trying to restore it is unsuccessful due to error 17. I tried to restore it with my laptop with an older version of iTunes and after starting the restore iTunes gives error 9 (hardware problem I suggest) and the iPhone screen gets red for a second. I tried kicking it out of recovery mode with iReb and iReboot but it keeps looping the recovery mode.
Any ideas/tips on how I could fix this before giving up and re-selling it? Thanks in advance.
Score 2
Add a comment
Chosen Solution
Have a look @ http://forum.gsmhosting.com/vbb/f933/iph...
Good luck.
Score 2
Add a comment
Hi,
Mostly it happens because of U2 IC problem so change it and give it a shot.
Or
Since it is a water damaged device then try to Red screen solution ,
I'm sure it will work.
Good luck
Add a comment
I had the same issue which you have, i don't know if you have already solve it or not, but i solved it!!! Follow this video https://www.youtube.com/watch?v=chZSdY5H..., i didn't work for me for the first try, but after trying a couple of times it worked!
1 Comment:
The link is dead. It says that the video is unavailable. Can you give details on what the fix was? Thanks!
by
Add a comment
Add your answer
iKatia will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 5,725
