Repair information for non-Apple computer keyboards.
243 Questions View all
How to repair charging port?
When I last went to plug in my micro USB charger into my Zagg universal Bluetooth keyboard, the charging port was pushed further back into the keyboard. How do I take it apart to repair this device? There are no visible screws anywhere.
Score 6
Add a comment
Most Helpful Answer
I just took mine apart. Use a heat gun to soften the adhesive, and slowly remove the rubber, then the case will seprate. The mirco USB connector is weak, and I have had several fail already. this part would otherwise be easy to replace, as it clips on, but Zagg will not sell the part. I may try to bypass the port, and charge directly to the battery...
Score 1
Add a comment
Not sure if this will help but here it goes. The connection was very loose and cable would fall out. The port was not loose, just seated far back. I took a file and filed down the cable plastic on the connector so it angled properly in relation to the case and port. Problem solved.
Score 1
Add a comment
Bought a new keyboard after mi puts roba
Add a comment
it broke off during normal use plus the wand has stopped working
1 Comment:
were do i buy new keyboard and wand
by
Add a comment
Add your answer
Lucas will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 51
All Time: 4,945
