not recognized by windows
isn't recognized by windows
Follow these steps and try to connect your device again.
1. Connectivity
Disconnect all USB devices from the PC, including printers, cameras and flash drives. Then connect the iPod to the computer using its USB cord. You can try all the USB ports on the computer to see whether a port or two is faulty. Clear the USB ports from any physical obstructions such as dust or dirt. The connection between the iPod and PC should be tight. If you have an extra iPod cable, use that one instead to find out if there’s a problem with the original cord. If the PC still doesn’t detect the iPod, restart it and install the latest software updates for Windows and iTunes.
2. USB Drives and Reinstallation
Verify that all of the computer's USB drives are installed and working properly. First, connect the iPod to the PC and quit iTunes if it opens. Then right-click Computer from the Start menu. Choose "Properties" to go to the Device Manager. You should be able to locate the iPod under the “Universal Serial Bus Controllers” section. If you locate it and notice a red “X” next to it, right-click on the selection to enable the device. You can also uninstall and reinstall the device to ensure that it works. If the problem persists, uninstall and reinstall iTunes with the latest version.
3. Reset
Simply resetting the iPod solves the problem. First, check that the iPod is fully charged. If it is, toggle the Hold switch on and off. Then press and hold the "Menu" and center buttons at the same time until you see the Apple logo. The center button is the dark grey circle that forms the middle of the click wheel. The logo will appear about six to 10 seconds after pressing the buttons.
Other Troubleshooting
If you have any security software running, disable it, since some third-party software is capable of preventing the PC from recognizing the iPod. If there’s another computer around, test the iPod on it to find out if the original one is faulty. If the PC still doesn't detect the iPod, to take it to an Apple Retail Store for service.
Hope this is helpful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 11
All Time: 70
