Released August 2012. Model Number VAP430.
1 Questions View all
Why did the Wifi and Bluetooth stop working on my Vizio Co-Star?
My Co-Star was working great. Then one day I could not stream and the touch pad and cursor stopped working. I tried the factory reset. The Blue tooth setting would not work. I skipped that step. When I got to the Wifi setting, I did not find any networks. I tried to manually add the Wifi network, and it still would not connect. I have been to the Vizio website and searched the Internet, but have not found a solution.
Score 1
Add a comment
Most Helpful Answer
Sounds like your network settings might've messed up. Is the co-star still in warranty? If so, I'd get a replacement from Vizio. If not, you can try Vizparts.com. They deal mainly with Vizio TVs and accessories.
Score 1
Add a comment
Just spray WD-40 on the keypad and battery compartment.Take out the battery's first.Works on other things like fan motors.The contacts get corrosion that acts like an insulator.
Darryel Hubbard
1 Comment:
Never use WD-40 on other things like fan motors as it is highly flammable!
by
Add a comment
Good afternoon. Buy console vizio stream player / VAP430, how to flash and where to get the software ????
Add a comment
I had to hold down the redet button until i got a fast flicker then let go n reboot too many signals
1 Comment:
where to get the firmware itself ?
by
Add a comment
Add your answer
Joe will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 5
All Time: 733
