The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
459 Questions View all
How to diagnose dead board of Galaxy SIII?
I was having problem with my USB charging connector and changed it, but now the phone is completely dead and does not power on nor does it charge or show anything on screen. The connector is fixed properly but still nothing works seems the board is dead. How to diagnose the problem?
Add a comment
1 Answer
Chosen Solution
Hi,
First check the battery voltage with a multimeter. If the battery is less then 3.8V, try to charge it externally.
When you have a charged battery, try to switch-on it. If the phone switch on normally then you have a problem with the charging.
If the phone can't switch-on, try to enter the phone into Android System Recovery menu or in Download mode (Volume Up+Home+Power or Volume Down+Home+Power). If you can enter this modes, maybe the problem is into the SW. You can reset it from the Android Recovery menu or to reinstall the firmware from the download mode. The battery must be at last 80% charged!!!
If no, try to connect the phone to the PC by holding the volume down button.
If the battery is charged and if the Windows can't recognize connected device, then you have a hardware problem.
Regards.
P.S. You can buy a JIG dongle for entering Download mode for Samsung Galaxy S3 or you can find easy in the internet how to make it by himself.
Add a comment
Add your answer
Huzefa Darolywala will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 3
All Time: 1,261
