Repair information for the 4th generation iPad. Released November 2, 2012. Model numbers: A1458, A1459, and A1460.
408 Questions View all
Main Camera not working but works with FaceTime.
OK this is a strange one.
I have an iPad 4 wifi +3G which i'm refurbing.
I have transferred the Motherboard battery & other parts across to a different casing which is in excellent condition.
The casing from original was pretty beat up & very badly damaged in one of the corners but everything on it worked fine including both camera's.
This is something i have done many times before without any issues so i'm not someone who is attempting this for the first time.
Everything is working fine except for the main camera when i try to use the camera app it just stays black & i can't switch cameras to the front facing one.
Also i cannot get a camera to work with photo booth BUT both camera's work fine when using FaceTime !!!!???
I have tried different headphone jack logic boards both brand new & from known working iPads I've also tried different camera's again new & from working iPads yes they work fine when put back into the iPads they came from.
I have DFU restored & updated to IOS 8.1.1.
Any ideas guys any help or suggestions greatly appreciated.
Thank you.
Score 2
1 Comment:
i have exactly the same issue, did you sort it? what was it?
by
Add a comment
1 Answer
Same thing happened after taking iPad to store to fix jammed earphone jack!!
Add a comment
Add your answer
Kenny Leonard will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 5
Past 30 Days: 11
All Time: 1,049
