Apple's 2012 first-generation 7.9-inch iPad mini, with 16, 32, or 64 GB of storage and an A5 processor.
630 Questions View all
Why is there a serial number in my new lcd display?
I have just received my new lcd display that I have recently order from ifixit last month (11/25/014)for my ipad mini, the repair went smoothly with just a few minor set back. After the installation
repairs, I turn on the unit, it power up the apple logo appears, no problems whatsoever. But I notice something. Half way down in the right side of the display, there appears a four digits, numbers 4904T. Thinking that I probably forgot to remove a protective sheet
from the display, remove the digitizer and check for the protective
sheet, but did not find any on the display. I have also check
the digitizer glass, but found nothing. Just to be sure, l turn on the
ipad without the digitizer glass, and chech the lcd display, the numbers are still showing on the screen. I have also open other
programs, like safari, apps, utilities, youtube and games, with the same results the numbers are still showing. Is this normal for a new lcd, if not how could I resovle this issue. Thanks.
Score 3
Add a comment
Most Helpful Answer
The lcd should always have a protective sheet on it sometimes it doesn't look like it because it's on very smoothly. Take a thin blade and try a corner.
If no luck then try some alcohol on the numbers and it should wipe off.
Score 3
1 Comment:
Its on the front side facing the screen had the same problem its clear and looks like its part of the lcd
by
Add a comment
Is the character color for the visible serial number written in red? If so, I had the same situation and it was the protective screen cover. As ‘con’ stated all you need to do is remove the protective film.
Thanks
Score 2
1 Comment:
you're a life saver dude
by
Add a comment
Add your answer
ramoncastro12 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 29
All Time: 1,868
