Repair information and guides for the fifth generation of iPhone. Model: A1387
2201 Questions View all
Dropped phone and screen is now discolored and cropped at the bottom?
Hi! I recently dropped my iPhone 4S out of my coat pocket. It went white with vertical grey lines for about 30 minutes. After resetting it with the home and power button, it came back to life, but the screen is exceptionally dark and objects are more "defined." On certain items, especially grey boxes, I can clearly see slight horizontal lines. The screen was flickering, but I turned off auto brightness. The final display issue is that there's a dark grey bar at the bottom of the screen that crops off the title of the apps in my home bar. There's no glass breakage, so trying to understand what parts I need to repair? Is this a true screen replacement or is it possible that a cord is disconnected or loose? What about the dark grey bar? Thanks in advance!
2 Comments
Same thing happened to my s9 but i didn't drop it
by
Same happened with my Moto g7 power. Has anyone gotten more than 2 weeks usage out of phone after this happened? I paid my phone bill yesterday, then this happened several hours later. Want to know if anyone's shut off or stopped working altogether?
by
Add a comment
Most Helpful Answer
Sounds like your LCD is dead.
You can try replacing the whole LCD and digitizer assembly.
Score 1
Add a comment
It means you should take your phone apart and reattach your lcd cables to make sure they are tightly connected. After the drop that maybe popped off your ribbon cables.
Add a comment
Same thing happened to my phone. Its an s6. I am worried about my pictures, files and music cause i have not backed them up.
2 Comments:
@ringalingringa If you replace the display all will be well with your phone . but if it still works enough to get into your phone then I would back everything up just to be safe first
by
But i didnt back up cause who knows if my phone was going to drop and turn black the next day. Would I still be able to see all my pictures. Im scared. It wasnt a very huge issue and is there any other way to still get all of my pictues if i have not backed them up?
by
Add a comment
You’re gay lol ahahahahahahaa
Add a comment
Add your answer
reeves will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 21
All Time: 14,214
