Mid 2010 Model A1278 / 2.4 or 2.66 GHz Core 2 Duo processor
795 Questions View all
Replacement screw for MacBook Pro trackpad clicker adjustment screw
While trying to adjust the tri wing screw for the clicker of my MacBook Pro Mid 2010, I striped the screw. I could possibles drill out the screw but can't find a replacement screw for it.
Score 2
1 Comment
I also have the same problem. I need to find a replacement screw tri wing size.
by
Add a comment
1 Answer
Most Helpful Answer
Some auto or hardware stores have a compound for stripped screws. You're not holding elephants you just want the screw to stay where you set it. (I'm assuming you can turn the screw to the proper height).
Gasket compound or superglue may also do the trick.
If this answer is acceptable please remember to return and mark it.
Score 1
Add a comment
Add your answer
Anky will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 465
