Identifiable by the model number S7562, the Galaxy S Duos is a dual sim card smartphone made by Samsung.
104 Questions View all
Why is my mobile is SLOW every time?
Dear staff,
kindly tell me what is should do to boost my mobile.
Hence i use wassup and fb messange with 1GB data .
I can not use my mobile every time. when i want to dial a new number the phone always hangs. Even when am in call or i want to check the contacts calander messages .And the ever worst is the camera. Every thing Hangs.
I brought this phone 3 months ago.
Thanks
Score 15
2 Comments
You were &&^&@@ by samsung!
by
This fix my slow and freezing samsung galaxy.
http://itrepairguide.com/samsung-galaxy-...
by
Add a comment
Most Helpful Answer
The only thing you can do is reset the phone to factory settings. You can do this through settings.
However, I would also like to point out that you have a "budget" phone which has a very small processor etc and it will be slower than, for example, the Samsung Galaxy S3/S4/S5/Alpha.
Even if the phone is relatively new, it's cheap.
Score 2
Add a comment
Hi,
Do you have this problems from the beginning?
First you can do a factory reset, but if you have important data, make a backup first, because this will erase all your personal data.
How to Wipe Samsung Galaxy S4 Data / Factory Reset
This will resolve your problem if it's from an application or settings.
Do a SW update.
If you have same problem after this steps, then the problem is HW.
From your explanation I thing you can have a problem with the camera, but I can't be sure.
Regards.
Score 2
Add a comment
8y67ughijo0p[oigutrdtyugijokpl[';
Score 1
Add a comment
With low processor speed, you may check any unnecessary installed applications and remove.
Score 1
Add a comment
yes
my phone is all time can be slow
Score 1
1 Comment:
yes when im using my mobile phone its so slow
by
Add a comment
reset the phone to the factory setting is the only solution for software change in the smart phone please ,try this method and if it does not work we will try other method after ur feedback
Add a comment
Very slow that mobile wha can to me
1 Comment:
Oak sir I am waiting from your report, which me
by
Add a comment
Add your answer
sdafra89 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 18,673
