Nintendo's upgraded version of the Nintendo 3DS. It features bigger screens, longer battery life, better pixel density, and a better design.
413 Questions View all
My 3DS XL has a block in the headphone port
When I were using my 3DS XL with headphones, the headphones broke and a piece got stuck in the headphone port. It means that I can only use headphones with a part removed. Here's what they look. (you can't see the block that's stuck there) What I can do to remove it?
Score 4
Add a comment
1 Answer
Most Helpful Answer
I'd say, first try using a pair of tweezers to reach inside the headphone port and pull out the broken-off part.
If it can't be tugged out, I would consider opening the device following this guide until I could get to the headphone jack, and then trying to either push the broken part out if there's an opening in the back of the headphone jack, or to perhaps get the contacts inside the jack to push less firmly on the broken-off part to make pulling it out with tweasers more feasible.
If that didn't work, I'd probably resort to unsoldering and replacing the jack, but if you don't feel comfortable with soldering you might or might not want to try that.
I'm no expert; anyone else have a better idea?
Score 1
Add a comment
Add your answer
[deleted] will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 47
All Time: 2,256
