Released on October 23, 2012. Core i5 or Core i7 Processor. Apple Fusion Drive.
208 Questions View all
Stripped Screw on Antenna Plate
So just as the description says, when putting one of the hex screws back in on the antenna plate, I over tightened and stripped one of the screws. And when I say stripped, I mean I stripped the threads, the screw just spins now and doesn't hold, it just falls out. Is there any solution for this?
Score 1
1 Comment
Were you able to solve this problem? I'm having the same issue
by
Add a comment
Most Helpful Answer
Usually it's possible to grab the screw with a pair of needled nose pliers. If not, you might have to drew the screw out using a drill.
Hope it helps!
Score 2
Add a comment
There's some really cool pliers designed for just this problem!
Screw Extracting Pliers
Screw Extracting Pliers Image
Product
$19.99
Score 2
4 Comments:
Its not the hex part thats stripped, its the threads female threads that are stripped.
by
To get it to hold back in place, you can always try using some Loctite or another type of threadlocker. Just don't get the super high strength stuff, or you'll do more damage.
by
Thats kind of what I was thinking...Guess I'll give that a shot.
by
Were you able to solve it? I have the same problem
by
Add a comment
Add your answer
betts211 will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 7
Past 30 Days: 23
All Time: 423
