A range of desktops aimed at the mainstream consumer market, spec-wise situated between the Inspiron and XPS lines released in 2009.
55 Questions View all
Random errors, but how are they connected?
I have multiple things that my Dell Studio 17 will do that all seem to happen at the same time, but don't seem to be related. Here is what happens:
  • Flash player stops working and crashes browser
  • Bluetooth devices will not connect
  • Skype crashes
  • iTunes will not open
I have no idea how any of these would be connected, but the all seem to happen at the same time. I am going to reinstall the OS soon, but I just would like to know for curiosity's sake.
Thanks for your help!
Score 1
Add a comment
Chosen Solution
Andrew I'm going to make a guess that you are probably using some form of Windows. The most likely common cause I can think of would be a shared dll that has become corrupted somehow. I believe your planned OS reinstall should clear your problem by replacing the dll. To be on the safe side I would install the programs one at a time and use them for a day or so before adding the next. That could help you find what is causing the dll problem. Hope this helps you. Ralph
Score 2
Add a comment
One easy attempt to repair it is by using system restore. look it up as it's different to access between operating systems. All you need to do is choose a restore point on which the computer was working fine; really easy. good luck!
Score 2
Add a comment
Add your answer
Andrew Guenther will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 7
Past 30 Days: 8
All Time: 879
