Automobiles by General Motor's Pontiac brand. Pontiac was founded in 1926 and became defunct in 2010.
336 Questions View all
Clicking noise when using external air on 2008 Pontiac Vibe?
Heater and A/C both work fine in the vehicle when using internal air, but when I want to defog the window or bring in outside air I get a rapid clicking noise coming from under the dash. Sounds like there is a switch that is trying to click open but is stuck, possibly something with the divider gate that switches where the airflow is coming from. Not sure how to better diagnose or how to get into the dash though.
Score 1
Add a comment
1 Answer
Most Helpful Answer
Ethan,
My dad had a very similar problem with his Silverado. As we learned, there are actuators within the dashboard that control the positions of the "blend doors". These doors control the amount of AC air that is mixed with heater air to achieve the desired cab temperature. The actuators are controlled by the car computer. The issue, at least in my dad's case, was that the alignment of the doors was off, so that when the temperature was set to max cold, the door hit the stops and could not move any farther. However, the actuator kept trying to move it, causing the clicking noise. I know there is a way to adjust the actuators/computer to correct the alignment, but I'm not sure how to do this, and it obviously differs from car to car. Also, just a heads up, the blend door on my dad's truck eventually broke off, and the repair is much more difficult once this happens.
Hope it helps!
Score 1
1 Comment:
I think this answer is on the right track. The actuators are prone to failure. Several YouTube videos show broken gears emiting loud clicking noises. The good news is that the part is relativly cheap ($35 USA). The bad news is not all of them (there are usually 3 units) are easy to get to. Sometimes the dash needs to be partially removed.
by
Add a comment
Add your answer
Ethan Lockwood will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 14
All Time: 1,739
