1.86GHz or 2.13GHz Processor, 128GB or 256GB Flash Storage
147 Questions View all
My MacBook Air Display is not working, it's broken? (I have a a photo)
I could put the photo now n.n, of my MacBook Air, I dropped it accidentally :( , but I want to know if my Display is broken or a cable inside it, what you recommend me to do?
Score 1
4 Comments
Can't access the image get: Unauthorized
by
Kevin, use this guide to add images Adding images to an existing question
by
There's the photo my friends:D
by
Thanks for posting the image. Sadly I think old turkey is correct here your display has had it. You can also try connecting your system to an external monitor to help prove this. If the image is good on the external then its a sure thing. See if you can locate a full lid assembly while being a bit more in cost it will be a lot easier to replace.
by
Add a comment
1 Answer
Chosen Solution
Kevin, that is a broken LCD. Part of the electronics that is connected to your LCD panel has failed. You could try and see if you find something obvious, but most likely you will have to replace the panel. Hope this helps, good luck.
Score 2
Add a comment
Add your answer
Kevin will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 1,280
