Model A1318 / 32 or 64 GB capacity
299 Questions View all
black screen after screen replacement connects to itunes
hi i replaced both LCD and digitiser but the screen remains black no back light or visual when i plug it in to itunes you can hear the bleeping sounds working fine and the ipod loads up correctly in itunes but still not visual i have tried usual fixes checking cables are connected correctly and using different lcd's. i have also tried restoring the phone and loading it in recovery mode by shorting the battery but nothing seems to work. the phone is now on, charging and connected to itunes and has been restores and is running IOS 5.1.1
any help would be great thanks
1 Comment
it would seem the lcd is faulty (so was the second one i tried) i tried another which had a faulty backlight but the visual still worked
by
Add a comment
1 Answer
Chosen Solution
Hi,
This happens because you install the LCD display into switched on device. Disconnect the battery or more easy, stay the iPod switched on to drain the battery alone.
Regards.
Score 1
Add a comment
Add your answer
jay will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 4
All Time: 64
