Score
Avatar
Michael Burdick
13
Asked
Dropped iPhone and now has white screen ...
History
I dropped my phone and the screen is now all white (http://img97.imageshack.us/img97/8936/iP...). The phone still connects to my Mac and I can answer calls (since I know where the slider is). So I'm taking that the sensors and everything work.
So do I just need a 3G display, or are there other parts I should consider buying?
Thanks!
Edited by: mayer, rj713, osvaldo, and oldturkey03 ( ) , bushing and Taylor Arnicar ( ) , Sterling Hirsh ( )
Post Answer
5
Score
Avatar
markus weiher
22.9k
Answered
Accepted Answer
PermalinkHistory
I would first try to reset the iPhone - press and hold the home button and the power button at the same time until the iPhone restarts - if you're lucky - it will work again.
if not - it could be the display connector that needs to be reseated
use the display assembly guide to open the iPhone and check the connectors - but be careful - if you short the contacts of the connector, the coil for the backlight could be damaged - so removin the battery would be a good idea
I tried a reset, still having an issue. I hadn't even thought about checking the connections first. I'll track down some spudgers and take a look. Thanks!
Michael Burdick,
this is more of a thank you. i had a white screen. i thought it was over. i put in google search and it brought me to this website. i have a 3G i did what you said. i held down the hold button and the power button and yAAAAAAAAA it it came back. i cannot thank you enough
thankful,
6
Score
Avatar
Akber Jesani
119
Answered
PermalinkHistory
I have seen this issue many times as i've repaired plenty of iphone 3g's. The main cause of this is from the impact of the fall related directly to the mother board.
Generally if you replace the LCD with a fully functional and tested LCD and you still get a white or flickering screen it means that the FPC Connector on the mother board has been damaged from the impact of the fall. The FPC connector is the part where the LCD is plugged into the mother board.
The FPC connector can be replaced but it is not an easy task, it requires patience and precision and working knowledge of soldering.
This answer was originally to another question.
Score
Avatar
illPod
229
Answered
PermalinkHistory
Check the connection is home for the LCD. i find disconnecting, blowing in both the connector tab and port then placing the connector squarely on top of the port and pushing down firmly usually does the trick.
If that doesn't work it may be that they are different versions/models of LCD? remove the LCD and check it against the old one, they usually have a (model) number printed on the back.
Update
Also make sure you hard reset the unit by holding both the power and home button until it reboots.
Edited by: illPod ( )
Score
Avatar
timbo
13
Answered
PermalinkHistory
I have also had some issues around a white screen. One point that has been made in one of the youtube videos is that connecting a new lcd to the logic board whilst it is still powered up will not resolve a white screen issue - the board has to be powered down when connecting the screen, digitizer and earphone connectors. Be careful to power down before connecting the new lcd.
Score
Avatar
Alistair Campbell
13
Answered
PermalinkHistory
My screen on iPhone 3GS also went completely white after installation. I used the reset method (holding the power button and home button together for 5-10 seconds). This reset my phone perfectly and it's working fine. Try this before reopening.
Score
Avatar
Olivia
13
Answered
PermalinkHistory
My phone does that , and my lock screen is broken .
If you blow in the bottom where the charging port is , it will fix it .
I know it sounds stupid and ridiculous , but it works ..
0
Score
Avatar
jorge leyva
Answered
PermalinkHistory
when you say "is cracked" i understand itÂŽs broken.
certainly you have to change the display of your device.
you have to buy it!
there is a lot of step-by-step guides to open a iphone.
have you any friend with the same model of iphone?
try to get it borrow to change display from your friendÂŽs iphone to yours, you will be able to know if the problem solve it when you change displays.
hope you can!
good way to lose a friend. Just buy your own parts.
mayer,
0
Score
Avatar
kupajava
61
Answered
PermalinkHistory
more often than not, the white screen issue is not "hardware" based. It may be, but try a from "firmware" rebuild and see if that helps. No guarantees but if you have already tried everything else I would suggest it as my wife's was having this issue and it seems to have solved the issue. That being said, I did change out my wife's battery and after a few "don't use the 3g parts on 3gs!" mishaps the firmware rebuild was the one thing that resolved the last (white screen) issue.
Only use this as a solution of last resort, but it worked for me. Many iphone issues on the 3gs have a "white screen" symptom but 3 or 4 times a rebuild from saved firmware fixed the issue.
Edited by: kupajava ( )
0
Score
Avatar
alejandrokm
Answered
PermalinkHistory
I changed the glascover of my iPhone because it was broken. After putting the new one on, all I had was a white screen display.... :s Till I found out that the connectors from the lcd display were damaged, so I had to replace the lcd, too. After that, my phone was working like in the good old times again.
0
Score
Avatar
Kathy Hughes
Answered
PermalinkHistory
Hi,
I have also had the white screen of death.
Here is my story...
Last week I dropped my iPhone 3GS.
It slipped out of my pocket while I was sitting on the couch.
I have dropped my phone before, but it is (or I should say was) in pretty good condition. You wouldn't know that it had been dropped, let's put it that way, no scratches no dents or cracks.
My phone fell approx 10 inches.
Right away I knew something was wrong, there was a popping type sound. I picked up my phone and tried to turn it on. The screen was white. I tried to turn it off but couldn't. So I force quit it. I then couldn't get it to turn back on. I was so mad at myself, but mostly just really really sad.
I scoured the internet for answers and came up with a few, button fixes this and that.
I took my phone apart, I mean I took off the digitizer and LCD, I also took out the logic board. I then put it all back together. Guess what? it worked! It came back on it synced with my mac and it all seemed good. The battery had been completely drained, even though when it fell it was just over 90% charged. I kept it plugged into the computer and it charged up to 100%, I then unplugged it, used it and all was good, everything seemed to work fine, I could make calls, receive calls, texts pictures, videos etc.
My next test, turning the handset off then back on.
It failed that test. I then kicked myself, why turn it off I had it working!
I tried what I had just done and again took the phone apart and put it back together. No good, all I had was a white screen.
I tried to clean the connectors. No good just a white screen.
I tried my daughters LCD. No good, her LCD went white, I by now was bricking it thinking I'd now messed up 2 iphones, when I put her LCD back in her phone it worked! I was so happy.
It didn't stop me putting my screen in hers though. No good, all I got was a white screen. I then put her screen back in. Her screen was now white as well!! That however was fixed with a reset (home and sleep combo). So I hadn't screwed her phone as well.
Well I ordered a new screen on the off chance. No good just a white screen UNTIL I did a reset with the new screen in place. Home and sleep combo, guess what? It is now working!!!
So I am assuming after changing the LCD for a new one that you still have to do a force quit due to the phone still actually being on when you take the front off.
I can't guarantee that this fix will work for everyone, but it did work for me. So try it it just might work for you as well.
Good luck
Can you please tell how to force quit?
hikansal,
I think he means holding home and power button at the same time for 10 seconds. This makes the iphone reboot, you should see the apple logo appear and you can release the 2 buttons and allow iphone to reboot. This works for many problems on iphones and is a good first line to repair..frozen apps, white screen, sound problems etc.
pollytintop,
0
Score
Avatar
lewis white
Answered
PermalinkHistory
i have a white screen to , i bourght an iphone 3g off my mate knowing it was like this , he says its the screen , the didgitizer is cracked to wich sugests that its been droped however , when he shown it me with the screen on it had a few lines down it i think . if i buy a new lcd and digitizer off amazon , will this fix it ? i dont think theres any damage to the board atall as it looks allmost pefrect please let me know what you think ! ;)
0
Score
Avatar
Kathy Hughes
Answered
PermalinkHistory
Hi,
One thing to check if you change the LCD an digitizer is that all the connections are on securely. After ingot my screen fixed and working, the sensors weren't working right, do the backlight wasn't going off when I was on a call. So i had to open my phone back up again and fix the problem. Make sure to use twizzers to get the sensor in and don't forget to push the clip down! (I don't remember which number it's labeled but it's the one that goes from the LCD to the phone with the little gold connectors on the tip). After you replace the screen and digitizer and your phone is back together hold the home button and the power button down to 'force quit' This trick worked to get the new screen working, as it didn't work the first time I changed it. After this I had a perfect new screen, no more white screen of death and a big smile on my face!
Hope this helps,
Kathy
0
Score
Avatar
HeLLRazoR
Answered
PermalinkHistory
Today I faced the same problem.. Screen sudden went White after dropping from lap.. then again i dropped it to check my luck.. but all went white.. Touch was working but then by mistakelly my finger pressed at bottom left of display where call back button popups..
then the phones screen flashed and came back again..
Thanks to GOD..
See Another reviewer (HELLRAZOR) said to press the phone in the bottom left of display. This, after holding the reset keys (both home button and power off button), worked! Good stuff. I think perhaps the display can come loose and simply pressing this area reconnects the phone's internal components. But then again, I am not an expert and share my luck after reading HELLRAZOR's suggestion. The white screen is gone after at least three hard reboots (holding two buttons mentioned above). The key was to press the lower left screen. ODD, but TRUE! Thanks!
lover4va,
0
Score
Avatar
charly
Answered
PermalinkHistory
force quit resolved my iphone issue - white screen. i panic and sad because i didnt know how to reboot my phone since power button is not responding. After reading this thread it helps me a lot. now my phone is working.
thanks a lot.
0
Score
Avatar
elizabeth
Answered
PermalinkHistory
my phone's screen is white, however I can still see all the buttons... my texts are impossible to read unless I copy and paste into the notes app. I havent heard of anyone else having this problem since it is not exactly the white screen of death... it is my second 3gs iphone to do this :( can anyone help? i restored it, did a hard reset, and nothing helps. esmith5288@live.com
Any news about your problem elizabeth? Igot the same problem! :(
eelectronix,
0
Score
Avatar
Craig
Answered
PermalinkHistory
I tried that but the white screen still continues to show, is the phone completely broke?
Craig, it might work better for you to ask your own question. This one is getting old and really confusing due to cross postings. Click on here http://www.ifixit.com/Answers/Ask/iPhone... and give as much information as possible.
oldturkey03,
0
Score
Avatar
mmmmm
Answered
PermalinkHistory
Hello, it should be the problem of the lcd flex cable... You need to replace the lcd display.. Here is the factory for this screen : http://www.eddogo.com/3g-lcd-display-tou... for your consideration
0
Score
Avatar
Caroline
Answered
PermalinkHistory
Hey, kind of a bit late to reply but mine had a similar problem, it was because the screen was too far away or something, try pressing the screen on to the thing just with your hands press very hard thats how i fixed mine but might be a different problem...? You have to hold it down just use boh hands to squeeze scfreen and back together and keep it like that see what happens, let me know if it helped at all?
0
Score
Avatar
Ian
Answered
PermalinkHistory
well i ecently bought a lcd screen beacause my iphone screen was broken. it worked notmal for about 5 days then the screen came white and i bought a new screen. the new screen wont even go white it just stays black what do i do?
0
Score
Avatar
john
Answered
PermalinkHistory
hi I got a iphone 3g with no power problem.i found the proximity sensor nap problem n replace it..next change home button and changed lcd but still there is white and black screen.but i tried with others iphone 3g upper part then it works...but when i tried with my repair one then i got half screen white and half screen black..i am on stuck..all are new i mean new lcd new home button,new proximity sensor nap but still it is not working.....can anybody help me out
0
Score
Avatar
mmmmm
Answered
PermalinkHistory
You may need a replacement for the screen with the working flex cable. This original lcd screen replacement should help you for this problem: http://www.eddogo.com/3g-lcd-display-tou... Thanks
0
Score
Avatar
gcscomp
Answered
PermalinkHistory
Yea we just changed LCD & Digitiser at Excel Mobiles and phone was already switched on due to fact without removing battery, we couldn't get it to turn off. Once replaced got same issue as mentioned above, and held down power and home and when switched back on phone was working like a charm :D
0
Score
Avatar
karwas
Answered
PermalinkHistory
Hold the on/off power button with the home button and let it hard reset. When it turns off just simply press on/off power button again to turn on and it should fix.
0
Score
Avatar
Chris
Answered
PermalinkHistory
@Olivia I want to say a HUGE thank you as you answer solved my screen problems! Blowing in the connector must remove dirt from a video out pin or something but that's what fixed it!
Add Your Answer
