Released at 2013, September. Display size - 480 x 800 pixels, 4.3 inches. Internal memory - 4 GB, 1 GB RAM. CPU - Quad-core 1.2 GHz Cortex-A5, GPU - Adreno 203
20 Questions View all
Why can I not increase the brilliance or back light
i have fitted a new screen and digiliser assembly and all is working i have reset to factory settings but the problem is the back light or brilliance is very dim i have gone into settings and it is on maximum setting i have also tried on automatic setting no differance can you help
Score 1
1 Comment:
can any one help
by
Add a comment
1 Answer
Hey grout705,
Did you try to change the backlight screen timeout, go to Settings - Display - Sleep. Then choose the screen time out duration.
You can also tell the phone screen to always stay lit when it is plugged in via USB. Go to Settings - Developer Options. Then check Stay Awake.
-If you tried those please comment to let me know.
*Hope this helps*
1 Comment:
I have the same problem...
Changed the digitizer and lcd unit, all works fine (after a terrible 10.000 times of in and out) but now the backlight is very dim.. Did everything you said but still no solution
by
Add a comment
Add your answer
grout705 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 7
All Time: 550
