Score
Avatar
Robert
37
Asked
iPhone 3G wifi not working - solution
History
Hello,
i have some news, for the people who's wifi is not working.
i tried many things and now have more concrete facts about this problem.
my wifi can't find any networks.
first i thought that the problem is the wifi antenna.
on ebay there are many "wifi antennas".
all the vendors tell that this antenna http://www.traderscity.com/board/userpix... handels the wifi. but its not.
i disconnected it at a phone where wifi was working.
after disconnecting wifi still worked, but gps was not working.
so the wifi antenna must be somewhere else.
i think that this part http://www.dealextreme.com/details.dx/sk... handels the wifi and the 3G.
i changed this part, but the phone was still not finding any networks.
so i thought, that the wifi chip on the logicboard maybe broken.
so i wanted to make another test and i installed the jailbroken app called "mywii".
with this app you can open a ad hoc network with your phone.
and it works.
so the wifi chip is not broken.
wifi antenna and chip are working fine. but phone is not finding any networks. this is very strange.
i have no idea what the problem can be.
but its not the antenna and not the wifi chip.
i also tried to reset network settings, made a update and restore. but nothing works.
Edited by: rj713, oldturkey03, and machead3 ( )
Hi Robert How did you install software on your jailbroken iphone when wireless was not working? I have the same issue and dont know how to install mywii to test thanks
John,
Post Answer
2
Score
Avatar
markus weiher
22.7k
Answered
Accepted Answer
PermalinkHistory
ok, lets try to sort it out a little bit.
you wrote about "mywi" - did you actually connect with the iPhone ? (especially - what distance did you have between the device you connected with the iPhone? - and of course - did you try to connect with the router - while you're standing beside the router?)
the first link didn't work - the second one isn't the wi-fi antenna
the wi-fi antenna looks like that: the connector is number 6 - so check the connection and of course check the contacts - if you bent the connector to much - the contacts could be broken and the result would be no or bad wi-fi reception.
Update
if searched my sources a little bit and found a solution posted in a gsm forum by "MPhoneClinic" (the mobile phone clinic from melbourne/australia)
i searched for a larger picture of the PCB and marked the part that you have to change
so, the good thing is - you know whats defect - the bad thing is - where to get the part and depending on the tools/skills you have - how to replace it.
but maybe you will find a good repair shop in your area who is able to fix it for you
Edited by: iRobot ( ) , markus weiher ( )
I made another test: i disconnected the connector nr. 6 and startet "mywii. i connected my phone with my mac and it worked fine. also a distance of 4 meters, didn't change anything. (without the antenna on connector 6.) Then i put my phone directly near the router (with and without the antenna on connector 6) but the phone doesn't find any network. that's because i think, that the antenna on connector 6 isn't the wifi antenna. but why can i connect the phone by using "mywii". and when i search for a network my phone doesn't find any. very stange problem.
Robert,
strange but almost common - read my update above
markus weiher,
Can you post the link of the site you have found? thanks a lot
Robert,
Can you please give me the direct link to the article. i can't find it
Robert,
Show 5 more comments
0
Score
Avatar
kenny
Answered
PermalinkHistory
Hi! i was having this problem in my 3g and solved it by doing the following..
install bootlace, install idroid, boot in idroid, turn on the wifi - power off idroid boot on ios 4.x..
wifi working.. i tryed everithing else except for the hardware solution and nothing worked (except for the freezer thing.. that worked for some minutes)..
i have wifi working for 3 days now..
0
Score
Avatar
Alejandro Ortiz
Answered
PermalinkHistory
The following clever little fix worked for me. I think what happens is the heat liquefies a broken solder point enough to reestablish contact. (I used the hair dryer option): http://www.google.com/url?sa=t&source=we...
Edited by: Alejandro Ortiz ( )
-1
Score
Avatar
victor Martinez
Answered
PermalinkHistory
well, If you want to have some minutes of wifi put your iphone into the fridge (cooler) near your frozen things... and in 10-15 min you take it away... you will get maybe 5 min of correct working of the wifi....
Add Your Answer
