Repair information and guides for the Apple iPhone 5c that was announced on September 10, 2013. Model: A1532, A1456
1234 Questions View all
Where is the Wifi Antenna on a 5C?
I recently repaired a 5C, doing my first screen replacement on one of these models. Replaced the screen and LCD assembly completely, bringing over the old home button, camera, earpiece, etc.
Now I have no wifi. The wifi is greyed out in the menu, and won't turn on. I believe I accidentally bumped the wifi antenna, but I don't have a clue- where is it?
Score 6
1 Comment
I can't see the Ici but ICI see the imei is and my Bluetooth don't work along with my phone saying not service
by
Add a comment
Chosen Solution
This is the wifi anntena here and it plugs in under the motherboard if you only changed the display then you would not even be close til this part .
I would try a restore first to rule out a a bug in the system if it's still greyed out after then you have damaged the motherboard in someway
Score 3
Add a comment
Sounds like somehow the wifi / Bluetooth IC chip got shorted.
Most likely when doing a screen replacement without battery plugged in.
Most likely your Bluetooth does not work as well.
Score 2
Add a comment
Add your answer
Ian Dalsin will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 15
All Time: 6,930
