Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Questions View all
Where is cellular antenna connector
Trying to figure out why i have no service. Have tried all the usual, reboot, restore, sim check. Have also replaced the dock connector but still wont work.
Works fine when in a really strong signal area.
Thanks in advance, Chris.
Score 1
Add a comment
Chosen Solution
it's the little gold prong on top of motherboard next to battery screws. easily bent when removing motherboard for battery replacements etc.
Score 2
Add a comment
Having a very similar issue and realising that the next place to look is the mainboard to antennae connector, it is just below the battery power connector (towards dock) and appears to connect to the metal ring around the glass of the phone and through to the antennae on located on the back of the dock connector.
Anyone is welcome to add more info or correct me!
Oh and someone seems to have done some soldering on my main board and that connector is missing! if anyone knows what that part is, or how I can fix without one...
Score 1
Add a comment
Where is the mainboard to antennae connector?
"it's the little gold prong on top of motherboard next to battery screws." (pollytintop)
Can you give me the link to the correct picture? I'm not shure what connector you mean!
Is it the one on the right?
http://guide-images.ifixit.net/igi/vutmf...
Thanks in advance!
Update
I think I know what you mean by "connect to the metal ring around the glass of the phone and through to the antennae on located on the back of the dock connector."
Its next to the "do not remove lable", right?
http://guide-images.ifixit.net/igi/UbuxL...
Score 1
1 Comment:
on your first picture you can just see a very small gold pin on top of dock connector... this is the connector from your dock antenna. the other "gold prong" is on the motherboard itself, next to sticker saying do not remove-it makes contact with the silver bezel surrounding the display. sorry but i don't know how to edit your photo to show you exactly what i mean
by
Add a comment
yes, i would like to know that too, since unfortunately there is no repair guide here for loose cellular antenna only for the GPS one, but GPS works fine. i have the same problem since i changed the battery. Seems that i was a little too clumsy but all main connectors (one through six) are fine... i guess.
thanks for helping!
volker
Add a comment
ah, mine is missing, probably where the last owner did as you said! Do you know where I can find this part, or if there is a work around?
1 Comment:
i asked this question a few days ago and am still waiting for a reply....think i might just take one off another broken motherboard and resolder. i'm sure the part can be made or bought somewhere
by
Add a comment
I fixed this on my iPhone by taking a short piece of earphone cable (thin and flexible), soldering it to the point on the motherboard where that copper piece used to be, and the other end to the little copper aerial piece on the dock connector (on that image it is the little copper pin to the bottom left of the battery power connectors).
Worked for me :)
Add a comment
I found a great tutorial on the net. Maybe it will help you!
"How I recovered my iPhone's lost GSM signal!"
http://www.mauron.net/iphonerepair/
2 Comments:
Look at page 17 in "iPhone_3G_Disassembly.pdf": http://manuals.4pda.info/Other/Apple_iPh...
by
There you'll find the Antenna Location.
by
Add a comment
i have same problem my iphone network works in very strong areas, n no service in another area. i have done all restore,reset etc but don't work.............. what to do
thanks in advance
Ramesh
1 Comment:
Ramesh, the first thing that you should do is to ask your own question. Right now it appears that you are answering an old question. Nobody will see that you are needing assistance. Click on the link "Ask a question" and give as much information as possible. This way others will see you need help.Good Luck
by
Add a comment
Found this answer at this link. Haven't looked yet to see if this will be repairable or will fix the problem or not. Good Luck.
http://cybermog.wordpress.com/2010/04/29...
Add a comment
Add your answer
Chris will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 39,469
