Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1169 Questions View all
Why isn't my Home button Not Working?
I resently took apart my phone. I manage to put every thing back and it works. but The home button isn't responding at all. I need help! oh I also Switched the motherboard with an 8gb so no i have a 16gb with an 8g housing.
Score -1
Add a comment
1 Answer
Chosen Solution
I would first check the contacts of the home button - maybe the are bent a little bit
Score 2
5 Comments:
Do you Know what i should Do because I dont want to remove the Black covering(home button)
by
I think that there are not so many options left - imho - disassembling is the only option
by
I think i may of found out the problem. The prongs that deal with the home button isnt touching the other prongs on the speaker system. Hmm just a little pressure in areas will get it moving but soon failed Suggestions?
by
I would try to bend them a little bit
by
If anyone is still looking here is what I have found.
1. After replacing the lcd/digitalizer or rear cover ensure alignment with home button prongs is accurate.
2.Ensure both prongs are intact and are in a position to reach the motherboard gold contacts when closed.
3. Also (and my issus was) ensure connector labeled "4" is connected, this is the flex cable connection the home button to the motherboard. Best of luck
iGuru Technologies
by
Add a comment
Add your answer
Steven Bolds will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 6,525
