Repair guides and support for the out of production cars and SUVs manufactured by the Saturn Corporation
72 Questions View all
Replace burned out Outlook XL brake light bulb?
How do I replace the burned out brake light bulb on my 2007 Saturn Outlook XL, FWD? I tried to fix it but I could not get to the light socket to remove the bulb due to the fact that it's got a cover on the inside of the brake light housing.
Add a comment
1 Answer
Chosen Solution
GruntUSMC, you have to pop out the rear light assembly. Loosen the two screws on the inboard side of the housing, then pop the assembly out. Check on here, different model; same idea. Hope this helps, good luck.
Score 1
1 Comment:
Thanks alot old turkey, this is what I needed.
by
Add a comment
Add your answer
GruntUSMC will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 910
