1.7 GHz dual-core Intel Processor (Turbo Boost up to 2.6 GHz) with 3 MB shared L3 cache
139 Questions View all
loud fan, screen blinking, not waking up
Just looking for some general maintenance tips, my air is about 2 years old and having some minor problems- the fan sometimes gets really loud and the computer gets very hot (almost burning), sometimes the screen flashes off for half a second and then turns back on again. Recently, if I close it while it's on, it will not wake up again and I have to force restart. Any tips on cleaning up hardware and drives to get it running like new again?
Score -1
Add a comment
1 Answer
Chosen Solution
First thing I would do is download a good fan & temperature monitoring app to see what is happening. I like this one Temperature Gauge Pro, others will work as well. It should help isolating out what is getting hot here.
I would also monitor was processes are running and what load they are putting on your system Check out Activity Monitor in your Applications Utilities folder. Its' possible you have a stuck process or infection running on your system.
While your system is on the newer side its possible the thermal paste on the CPU chip is not doing what it needs to do. Follow this IFIXIT guide to get to the heat sink MacBook Air 11" Mid 2012 Logic Board Replacement. Make sure to use a good quality paste. Here's a guide on how to clean the parts and apply the new paste Technique: Applying Thermal Paste.
Electronics Skills Image
Guide
How to Apply Thermal Paste
Difficulty:
Moderate
5 - 20 minutes
MacBook Air 11" Mid 2012 Logic Board Image
Guide
Difficulty:
Difficult
20 minutes - 2 hours
Score 1
1 Comment:
Thanks for the suggestions, I should note that I usually have a look at CPULed when the fan comes on, and the application taking up the most power is just listed as "kernel". Goes away when I restart but still a pain in the rear. I'll try your suggestions and see if they help.
by
Add a comment
Add your answer
Angela Kay will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 349
