Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2396 Questions View all
deadspot on digitizer iPhone 4
hi i got an iphone 4 with an cracked lcd, i replaced it with an new lcd and then i saw that it had an deadspot on the right side/middle of the screen, i thougt that the cable connections werent fittet right so i doublechecked it and that dident work :-( so i tried with another new lcd screen and it is still the same! is it the logicboard that does that then??
p.s i have repaired over 40 iphones without any problems this is the first time for me where i dont know what to do??
greetings from denmark
benny schnuchel
Score -1
Add a comment
I suppose you have given the answer. you can try the new two LCDs on another motherboard, if they are okay, it must either be the connector on-board or the logic board problem.
So check the pins of connector on board.
Add a comment
Yip sounds like you have damaged the motherboard was the touch working prior to the new screen
Add a comment
No when the screer was cracked there were no response in the same area ! So it is prberly the mother board that is damaged :-(
Add a comment
Add your answer
benny will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 162
