Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Questions View all
Please help! Battery iPhone 5
Hello Guys,
i got a problem with my iphone 5G. the iphone works perfect but the battery drain is very high and after the battery is empty the iphone stays off but after a while the battery doesnt work anymore. iphone turns on and off normal. i changed the battery same issue. high battery drain (12hours) without using it and after battery is empty battery wont work anymore.
any suggest?
thanks in advance kind regards
Score 1
2 Comments
ever gotten water in it?
by
never -ever gotten water in it
by
Add a comment
Most Helpful Answer
Sounds like damage to the motherboard either by pry damage or dropping it
Score 1
Add a comment
I have same problem with my iPhone.i think its problem with power management ic. If the phone has not been opened send it back to apple with original things and they should sort it out.
Update
I got a new battery charged it my mates phone and put charged battery in my iPhone it worked as long as I didn't let battery die would charge up aswell but once battery died it just would not boot. I just bought 2 new batteries but its just not booting up nothing just dead.am hoping to reflow power management ic.but I'll try doing what old turkey said first though let you know outcome. But if you have original things in it send it back to apple doesn't matter if it is out of warranty.there has been lot of problems on ios 7 with battery so they should sort it for free worth a shot
1 Comment:
it is out of warranty. i can't get a replacement. already called apple.
what is the solution if it is the "power management ic" or what else i can do? what did you do with ur i5 with that same problem?
by
Add a comment
DanielAA, before going to check your PMIC, I would go and replace the lightning connector. It is entirely possible that your battery is just not charging. If that does not work, then you could check the charging circuit out. It is always possible that the Charging and USB Control Chip CSD75202w15 has failed or needs a reflow.
Hope this helps, good luck.
Add a comment
Add your answer
DanielAA will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 8
All Time: 452
