The wi-fi only version of Apple's iPad Air, model number A1474. Available in Space Gray or Silver, it packs the custom A7 processor and ships in 16, 32, 64, and 128 GB configurations.
299 Questions View all
connecting charging port ribbon cable to circuit board
How does the charging/docking port ribbon cable secure to the circuit board the ribbon cable seems like it was glued with epoxy or somthing .not sure ..way to small for solder..it was originally attached flat to the board...
Score -1
Add a comment
Chosen Solution
The charging port ribbon cable comes with it's own adhesive, so it can be glued on.
You can see the link of dock connector flex cable replacement, the area with blue film is where the adhesive on.
Add a comment
I had to remove the motherboard to check this out the other day. It is soldered to the board. Not glued.
Add a comment
Add your answer
greg will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 5
All Time: 760
