Model A1502 / 2.4, 2.6, or 2.8 GHz dual-core Intel processor / Released October 2013
552 Questions View all
Where are the power on pads?
Where are the power on pads located on the macbook pro retina late 2013 logic board?
Score 5
1 Comment
I needed the exact location. I have diagrams for all but this model. The keyboard connector block on this model is not the same as the 2012.
by
Add a comment
Chosen Solution
Asked and Answered. Some of the newer models do not have jumper points you have to short the keyboard connector block (do not have the keyboard connected when you do this).
If this answer is acceptable please remember to return and mark it.
Score 1
2 Comments:
Hi @machead3, can you please provide more detail on this, as I too have his problem and need to know the specific locations of the keyboard connector block and how to disconnect the keyboard (If this model doesn't have power-on pads)?
by
afoulds, there are power-on pads. If you ask your own question (not a comment)and add an image of your logic board with your question, I can point those out. Otherwise just shorten pin 5 of your keyboard connector to ground. Check on here Where are the power pads on this early 2013 MacBook Pro Model?
by
Add a comment
Most Helpful Answer
Ok Guys, for the MBP Retina late 2013, I come to found where is the power on pad located. I'm gonna upload the picture in a couple minutes
Score 2
1 Comment:
@doriservices you need to post your images with your question on here I ain't see them on mine (Power-on Pads)
by
Add a comment
Hello Tom how are you doing….?
Listen first of all you should troubleshoot your mac. And you should have know if the power cord is correct, the I/0 left on the Mac is working fine, and at last there are two pins on the witch gonna let power on the mac without the power button…..
Well, go check them and post the results surely
Score 1
1 Comment:
Hi Wilson,
yes, i am sure that the power cord is good
I found this site http://www.insidemylaptop.com/turn-on-ma... but I did not find the corresponding model to mine. So I do not know how to try to get started without the keyboard
by
Add a comment
OK guys here are your power on pads
Add a comment
Hi guys, where are power on pads MacBook Pro 2014 Retina display?
1 Comment:
This are the same as the 2013 model i try and get the MBP to power on
by
Add a comment
Hello,
I have a macbook pro retina 13 inch (A1502 emc 2875 end 2013 to mid 2014). the mac does not start anymore. I can not find the handle for this model.
Could you help me
thank you
Add a comment
Add your answer
boo will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 39
All Time: 13,293
