Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
799 Questions View all
new battery, still wont charge
Just switched out battery but it still will not charge. Please help!
Score -1
2 Comments
Have you tried a new charging cable, different AC adapter, different USB port? Does your iPod still get recognized when you lug it into your computer? does it start up with the new battery?
by
It does start up with the battery but I've 2 difderent chargers, connected to the computer and it didnt recognize it.
by
Add a comment
1 Answer
Most Helpful Answer
faustgarc, sounds like you are having difficulties with the dock connector. Check to make sure there is not dirt, debris or broken/bend pins. Clean the connector with a few puffs of compressed air and high grade isopropyl alcohol. If that should not work, you may have to consider replacing the logic board. The 5th gen Video has a dock connector that is soldered to the board, and as such a pain to replace.
Score 1
Add a comment
Add your answer
faustgarc will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 90
