Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 Questions View all
Why does my MacBook 13" early 2009 power adapter burn out?
Maybe someone can help me?
I keep on burning out power adapters (60 watts).
I bought a new computer (used but new to me) and the adapter worked for about a month. Then for a few days it only showed the computer was being powered by electric current then it died completely.
I bought a new power adapter and after 24 hours of recharging it went dead (it is an apple origanl)!!!
I used two different outlets.
What am I doing wrong?
Thank you very much
Shevach
Score 1
Add a comment
1 Answer
Chosen Solution
Here's an interesting article that may shed some light on your problem, overheating power adapters are a common symptom for a lot of users. Generally it can range from a faulty laptop, to a faulty power adapter (with many even after several replacements), to an outlet in your wall that is too high or too low in power.
http://www.evancarmichael.com/Technology...
A good tool to show your battery usage and power is a utility called coconutbattery which you can download here:
http://www.coconut-flavour.com/
Score 2
2 Comments:
Gary, I can't thank you enough for that article!
After reading that there are so many problems that it could be I made a simple calculation.
It's the third computer and the third adapter with the problem. So I deduced that there problem isn't there.
All of a sudden it hit me! The only part that was common to all of the above was the plug from the wall to the adapter.
I opened up the plug, tightened the connection and my "over a year" problem was over!!!
Thanks a lot
Shevach
by
Anytime Shevcach, it's a pleasure to help, if you ever have any other issues, please come back and we will respond as soon as we can. Congrats on your fix!!
by
Add a comment
Add your answer
Shevcach will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 5
All Time: 1,091
