The Samsung Galaxy S II is a smartphone designed, developed, and marketed by Samsung Electronics with Android 2.3 "Gingerbread."
201 Questions View all
Touch screen gets crazy after glass assembly
Hello .I just made a full housing replacement on my samsung galaxy s2.but i have a problem with the touch screen.when i press a little bit more than usual it the touch "stucks" and start random taping.so i removed the glass again and tried to make it reviel the same problem without the glass and i couldnt!it was working perfect.when i put the glass the touch gets crazy after some taps.Whan can i do?does it need uv glue?will uv glue fix that?
Score -1
Add a comment
1 Answer
Chosen Solution
maybe that you still have the plastic on the glass. it is stuck with static so could cause phantom touches. Really basic but may be something that would cause this issue.
1 Comment:
well no the plastic is removed
by
Add a comment
Add your answer
Michail Pappas will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 130
