Repair information for the iMac G4.
130 Questions View all
PSU voltage: 12 V stable - 5 V NOT stable
Hi ....
i hope that someone here can help me.
I habe a problem with my G4 that won't turn on.
I tried everything i found on the web including change of 3.6 LiIon Battery and all the reset stuff.
I ended up with disassembling the G4 and took a look at my PSU.
I measured some of the voltages ...
AC / DC Board gives me more than 400 V of a stable DC voltage
DC / DC Board gives me a stable 12 V voltage between one black (GND) cable and 4 of the yellow cables of the mainboard-plug.
But between the black cable and the blue cable i get voltages between 0.8 and 3 and just sometimes up to 5 V .... it isn't stable at all .
I suppose there should be a stable 5 V voltage between the black and the blue cable??
I tried changing some of the capacitorc on the DC/DC board (2*10uf and 1*1uf) because i heard that they often are responsible for PSU problems but it didn't change anything.
Should i try to change the other capacitors too ?
Or could there be any other reason for the unstable voltage ?
Hope someone of you can help me
Thanks in advance
Oliver
Score -1
Add a comment
1 Answer
Most Helpful Answer
Obi B, not sure where you got the 400V. May be you can post a couple of images and show us where you are measuring your voltages. Take a look at the attached image and see if you get those voltages.
Score 1
1 Comment:
Hii oldturkey03,
thanks for response, sorry for late answering.
since 3 days iMac is up und running. Don't know what exactly solved my problem.
Changed 3 capacitors on DC/DC board i described in my first post.
Resoldered soldering joints from onboard connector on DC/DC board
Used contact spray on mainboard-cable-plug (blue cable)
checked if cables were well fixed in the plug.
Reasembled, now it's running!
@measuring voltage:
PSU in my case (G4 15 inch) consists of two parts.
1st part: The AC/DC board that converts ~230V AC to ~418 V DC and is connected to the DC / DC board with a two-core-cable.
2nd part: The DC / DC board that is supplied by the AC/DC board and has a 14pin connector that connects to the mainboard/DVD&HDD by cable.
My plug:
7 black (bk) on one side
4 yellow (y), 1 blue (b), 1 yellow, 1 red (r) on the other side
X = plug connector lock
y(2) bk (1)
y(3)
y(4)
X y(5)
b(6)
y
r
Again sorry for late answering, thanks
Oliver
by
Add a comment
Add your answer
Obi B will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 2
All Time: 158
