4 inch display / Available in a variety of colors / Released in 3 different models / 16, 32, or 64 GB capacity
331 Questions View all
Home button not depressing, but works when front is removed?
Hello,
I have an iPod touch 5g which I repaired the screen on, when reassembling I found that the home button seemed jammed, but there is no sign of catching.
when I took the screen back off I can depress the button on the ribbon cable and it works fine, but when pressing the button on the front of the screen it does not even move, can anybody help me with this?
Many thanks,
Tristian.
Score -1
Add a comment
1 Answer
Check the clearance of the button and the screen you may have been given a different screen then you needed also make sure everything is aligned correctly and in position I know usually when it comes to the Home buttons usually is the alignment because it can be tricky but it also may be because the screen is pushing up and jamming the button.
Add a comment
Add your answer
Tristian will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 228
