Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
797 Questions View all
My iPod will not turn on , why?
My iPod will not turn on , it doesn't matter if I plug it in to my I Mac or not I still get no response . I have not used the device for 9 months but it worked when I stopped using it . The iPod itself is in excellent condition by all appearances.
Score -1
Add a comment
Have you looked in the dock? Check to make sure that the port is still intact and fine. If it is damaged, you will have to replace the main board.
2 Comments:
The dock is in like new condition , the port is intact and complete .
by
Trying plugging it in to a wall charger (the OEM charger, 2A output) and try a reset on the device (holding the power and home button down for ~7 seconds).
by
Add a comment
Tom Lloyd, it is possible that your battery has been discharged below the threshold for it to be recharged. Sometimes a AC adapter can wake it up and charge it since it applies higher amperage than the computers USB port. If that does not work, I'd start off with a new battery and then re-evaluate. Hope this helps, good luck
Add a comment
Add your answer
Tom Lloyd will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 6
All Time: 125
