The Samsung Galaxy S II is a smartphone designed, developed, and marketed by Samsung Electronics with Android 2.3 "Gingerbread."
201 Questions View all
Screen black and no access to icons?
Dropped phone and small patch appeared in right bottom corner. Phone still worked, then screen started discolouring and eventually turned black. Icons are behind but not accessible. Calls and messages still being received. what have I damaged and can it be fixed? Please
Score -1
Add a comment
1 Answer
Most Helpful Answer
Your title and description are a bit conflicting. You say the screen is black, which leads me to think you can't see the icons. That sounds like the LCD is broken.
Then you describe the screen as being able to see the icons, but they don't respond to touch? That sounds like the digitizer is broken.
But calls and texts are still being received and I guess you are answering the calls and texts? Or they are just being received?
Sounds like you need the touchscreen assembly replaced. That is the top glass, digitizer and LCD assembly all made together.
Score 1
Add a comment
Add your answer
gransan06 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 110
