Repair information and guides for the fifth generation of iPhone. Model: A1387
2193 Questions View all
My iPhone microphone wont work
Hey.So i got this problem on my iphone 4s.When i call someone i can hear them but they cant hear me.I've even changed the microphone that didn't help either, i cant even replace my iphone 4s at the apple shop because i have opned it and changed the microphone, what's the problem?
Score -1
Add a comment
Did you change the dock connector ?
Changing the dock works 99% of the time unless you got a faulty part or a motherboard issue..
Try a dock from a known working iPhone then you will no if it's the motherboard
3 Comments:
Okey, i will try that and see it helps.Thanks :)
by
Hey.I tried to change the dock, and it still gave me the same issue, i had to scream so the other person could hear me.I found the problem my iphone was having, i had to loosen the backside of the iphone 4s and put something under the microphone/dock so the other person could hear me.And I'm asking how do i get it 100% normal?
by
Did you use the plastic microphone bracket on your new mic?[image|341695]
by
Add a comment
See image content:
Add a comment
The new update causes this 7.2 version.
Add a comment
Add your answer
hami will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 509
