Second generation of Wi-Fi iPad, released on March 11, 2011. Model number A1395. Repair is difficult and will require heat.
250 Questions View all
Question Closed
Replaced digitizer ripped the wifi, repercussions of this?
I saw there was already a person that had done this and got an answer, that one probably needed to replace the wifi antenna.
But I want to know why. The wifi antenna broke at the 2 screws that holds it to the outer casing (i believe its the outer casing atleast). I started the Ipad up and it finds my wifi no problem.
Is it that the wifi gets a weaker reading signal, or...
If its just a little bit weaker, I can live with it, but if its something else and its gona give up all together at some point, I don't want that.
Add a comment
1 Answer
Yes, your Wi-Fi signal and speed will be slow, you should replace the antenna, if just takes 5 minutes.
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 136
