0
Score
Avatar
carlweir
11
Asked
iTouch stopped working after being dropped in cereal
History
My son dropped his iPod Touch into his cereal bowl this morning, milk and all. It stopped working as a result.
My current plan is to give it time to dry out and then see if it will start back up.
Is there anything I should/could do prior to trying to start it back up?
Also, if it doesn't start back up, is there anything else I can do?
Edited by
Post Answer
3
Score
Avatar
bac
5.1k
Answered
Accepted Answer
PermalinkHistory
your idea to let it dry out first is a good one, it may take time to dry out thoroughly
there's another almost identical question from about an hour ago, rather than repeat what was said perhaps take a look over here:
http://www.ifixit.com/Answers/View/1634/...
good luck
Thanks! I'll give it a shot.
carlweir,
2
Score
Avatar
Matt Barnes
6.6k
Answered
PermalinkHistory
Liquid damage is a killer for electronics. First thing is to turn off the iPod and remove it from it's power source. Hopefully this will prevent the logic board from getting shorted out. Next, I recommend taking the iPod apart following our guide and letting it dry out for a few days. While the iPod is apart and drying out, you can use some rubbing alcohol and q-tips to try and clean any milk residue you see. The rubbing alcohol evaporates quickly and will not damage the iPod further. Finally, put the iPod back together, cross your fingers, and hope it works.
If that does not fix the problem, then you probably, at minimum, need to replace the logic board. Hope that helps you.
Thanks! I'll try drying it out, following the guide.
carlweir,
0
Score
Avatar
marshall
Answered
PermalinkHistory
i had same problem with a pool though and yea i just let it dry out and it works for the most part fine now
Add Your Answer
