The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
459 Questions View all
My phone was frozen in ice
I lost my phone a day ago n I found it in frozen in ice next to an ice rink and it wont turn on but I don't have a charger handy but I want to know wat I can do if it doesn't turn on when I find a charger?
Add a comment
1 Answer
Chosen Solution
Xavier Aquino, STOP!!!!! DO NOT EVEN TRY TO CHARGE IT OR TURN IT ON. Hope I got your attention :-). Since it was frozen in ice, treat it the same as you would treat any water damaged phone. By trying to turn it on or charging it in its current condition, you are running a very high risk of shortening out the logic board etc. Remove the battery and disassemble your phone using this guide. Clean every part, including the connectors on the board as well as on the cabled with 90%+ isopropyl alcohol and a soft brush. Be diligent about it and clean it well. This does not mean to scrub hard, just rinse in alcohol often. Check for any burned looking or missing components.After that replace the battery (not an option but a must), reassemble it and re-evaluate. Hope this helps, good luck.
Score 1
Add a comment
Add your answer
Xavier Aquino will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 452
