GSM iPad 2 with 16, 32, or 64 GB of storage, and a Dual Core A5 Processor. Model Number A1396. Repair is complicated and requires heat and prying.
152 Questions View all
Touch Screen (digitizer) tempramental after new one fitted?
Firstly I have now successfully removed and fitted over 50 new digitizers on Ipad's including 10 iPad mini's.
The one in question was bought to me after a failed DIY fix. I have attempted to fit 3 different digitizers that work perfectly in other machines but without success.
The problem is very temperamental, sometimes the touch screen will work perfectly and at others not. I have attempted to apply pressure at different parts of the PCB without change, the ribbon clips and connectors look ok under magnification and I have restored the devise back to factory setting and updated. Nothing makes any difference.
Be grateful for any help and advice - many thanks Dan
Score 1
1 Comment
Hope it's not bad manners bumping my question?
by
Add a comment
Most Helpful Answer
Assume the black fpc connector latch is faulty. Wedge some thin stiff plastic on top of flex and leave latch up. If this fixes it, you need a new fpc. If not, come back and we can look for missing continuity on the board
Score 1
Add a comment
Hi Dan, try putting pressure on both the the digitiser connectors, and see if it works, keep putting pressure while your testing the digtizer
1 Comment:
Thank you for the advise Waseem,
I will give this another go but pretty sure I have already tried this. My first suspicions were that the connectors had been damaged.
I'll get back to you once I have investigated further - thanks again Dan
by
Add a comment
@ jessabethany - thank you for that I will give it a go and get back to you. :)
Add a comment
Add your answer
Dan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 11
All Time: 456
