Second generation of Wi-Fi iPad, released on March 11, 2011. Model number A1395. Repair is difficult and will require heat.
250 Questions View all
Question Closed
vertical flickering colored pixel lines occur, then display bal
Ipad 2 LCD has an issue randomly. During work vertical flickering colored pixel lines occur and then display goes balck. Unit was not dropped. I have sound because it lets me know i have email. Digitizer works, i will swipe my finger where you unlock and it makes the unlock sound. I attached to my LCD display via VGA accessories cable after getting black screen and ipad displays on tv. I can work on iPad and see everithing on TV without any flickering lines. Not sure if it is logic board issue or something less serious. Do you have any suggestions? Thanks.
Add a comment
1 Answer
It seems like you are having problems with the LCD display. You can still hear sounds but it is not displaying on your screen. I'm pretty positive that if you replace the LCD then that should fix the problem. I hope that this works for you. Have a great day!
Add a comment
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 459
