no water out the brewhead
everything works, but the water coming out of the brewhead is a couple drops? do i need to disassemble the brew head and clean?
When you say brewhead you mean without the portafilter in place, correct?
If the water flow from the wand is fine then there probably is a blockage in the brewhead passage; if so it's most likely to be calcium and you might be able to fix the issue by descaling the machine. If this doesn't help then removing the screen, boiler screw and spring/valve assembly should allow you to inspect and clear whatever the blockage is.
If the flow from the wand is poor then you could be looking at a larger calcium buildup or a failing pump. I would still run a descale cycle first before purchasing a new pump.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 455
