The Nokia Lumia 800 is a Windows Phone smartphone with a 3.7" display and 8-megapixel camera. It is also known as the Nokia Sea Ray. Released in November 2011.
10 Questions View all
Question Closed
no sound after fall
Hi, My Nokia lumia 800 after a "small" fall it hasn't any sound from speaker.
I can listen well from ear-speaker, the microphone works fine and with hads free the sound works.
But the speaker does not work at all after the fall.
If I change the speaker-micriohone circuit
will my phone-sound repaired?
http://www.replacebase.co.uk/nokia-lumia...
Add a comment
Yes
When you dropped the phone the speaker was probably damaged or its connections were ripped off the board. Check everything else works first to confirm it was not the motherboard damaged in the fall. If the wire has come loose and you know how to solder then you may be able to repair it yourself.
Add a comment
Hi Oli thnx for your response,
I have already dissasemply my phone waiting for the replacing speaker, I download the service schematic manual for lumia 800 and i see that the hands-free speaker with the loud-speaker is in the same circuit in the motherboard so i suppose too that if my motherboard was damaged i couldn't have sound either from hands-free, anyway i found the speaker on ebay from china and i order it.
I will inform for the results
Thnx again for your response!
Add a comment
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 9
All Time: 1,135
